Low power.
fctry286
WhisperMax
Jul 30, 2010
254
San Diego.
Truck seems to have low power on the highway. Ill be cruising and roll into the throttle and it wont do anything. I have to almost floor it to get the truck to start boosting.
I changed the fuel filter and it didn't help.
Driving on the street feels fine. Not sure what's going on. Any thoughts.
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
Has it always done this on your current tune or is it new. And log it obviously. See what timing, pw and pressure are.
GeneralTJI
Turbo Todd
Jun 1, 2010
1,272
Colorado
Has anything been changed on the truck, mechanically or tuning?
Edit: nevermind on the tuning
MAF clean? is it smoking or clean when it has no power?
fctry286
WhisperMax
Jul 30, 2010
254
San Diego.
No nothing. Changed the converter 2 weeks ago. Didn't notice then. I put precision puller in. Once I get boost up passed 8 its fine. It just feels like its taking longer than normal.
PAT
EASY DAY
Aug 21, 2011
1,100
your back yard
Shoulda bought a gmc. Hasn't your truck always lacked in the power department? :):hug:
Clean Maf, air filter may be dirty. Or maybe it could just be how this new TC feels? Was it like that after the TC was swapped?
Still say 3k rail at idle is good.
fctry286
WhisperMax
Jul 30, 2010
254
San Diego.
maybe lift pump then. idk. I did notice that it only does it at 1500 rpms or below on the highway locked up. I just ordered new fuel filters. we will see after that.
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
It won't downshift out of OD? When you roll into the throttle does it smoke like crazy? You are just rolling into the throttle ,what happens if you just floor it?
I think it's just the choice of TC you have. I believe that until you reach stall speed you aren't going to build any boost. Rolling into the throttle on the highway is no different then sitting in the staging lane building boost getting ready to launch.
GeneralTJI
Turbo Todd
Jun 1, 2010
1,272
Colorado
The precision sledpuller is a pretty high stall converter from what I understand. This will make the truck feel weaker until it locks. Your slipping and loosing quite a bit more power vs. a stock stall speed converter. Maybe this is the issue?
fctry286
WhisperMax
Jul 30, 2010
254
San Diego.
It does shift out of OD. It may just be the TQ choice. I never noticed it until now.
fctry286
WhisperMax
Jul 30, 2010
254
San Diego.
Ok so the CP3 is coming out. FML. going to change it out. its the only other thing. new filters, no boost leak. bolts are stripped on the fpr so i am changing both.
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,492
472
Central OH
If hes rolling into the throttle at highway speed it shouldnt matter what converter it had if its locked in. Check for air leaks pre turbo.
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,492
472
Central OH
Well yes, check for exhaust leaks but they should be spotted pretty easily from soot tracking, what I meant was a leak in between the filter and turbo inlet
fctry286
WhisperMax
Jul 30, 2010
254
San Diego.
ok. well I changed out the cp3 and fpr. its better but still not that same.I just got my new filters and nicktane adapter. we will see.
