Low coolant??
DetailsUnlimited
1,264
Benton, Ar
I was told I have a bubble in my motor or radiator? Coolant keeps blowing out of the blow out tube? I guess this happened when I deleted the egr? Any suggestions how to fix this. Open the cap and let it run?
13,714
776
I fill the coolant system with the bleed screw out, truck not running. Once it coolant runs out, put the bolt back in and continue filling the tank. I've never ever had a problem doing it that way. If you still blow coolant, you may have a another issue.
DetailsUnlimited
1,264
Benton, Ar
Thanks again guys for the help! There was alot more air than I thought in it! Popped the bleeder screw and ran til coolant poured out. All good! I couldn't imagine not having this site for info!:hug:
DetailsUnlimited
1,264
Benton, Ar
Took truck to dealer and had a full vac and refill on radiator. Did not work still blowing coolant out of box. Replaced both thermostats and let run for 10 mins and will not get up to temps. Stays at 160? Any ideas?
