LLY: low coolant
WolfLMM
Making Chips
Nov 21, 2006
4,005
25
AL
Just bought a flat bed at work. Its a 2005 LLY zf6 never been hottroded. It was really low on coolant when we bought it.
It doesnt build pressure in the coolant system if the truck is only run for 10ish minutes.
Places to check?
bullfrogjohnson
Big Girl!
Nov 20, 2006
4,167
Locust, NC
Places to check?
do you let it cool down before you crank it back up for 10 minutes? smoke or funny smell in the exhaust? Have you tried pressurizing the system?
WolfLMM
Making Chips
Nov 21, 2006
4,005
25
AL
No. No. No.:spit:
temp gauge was all over the place, prolly due to the low coolant.
z79outlaw
793
Salem WI
Water pump weephole, Leaky EGR cooler, my 05 was about a half gallon low 2 weeks ago, turned out to be a leaky egr cooler. Was easily diagnosed because it looked like I had a oil leak on top of my passenger side valve cover and it looked like there was oil running out of the EGR cooler.
Weep hole just jump underneath your truck with a flashlight the underside of the waterpump you should be able to see a little 1/4" hole, check for signs of moisture, those are less serious problems that seem to have a common occurance.
WolfLMM
Making Chips
Nov 21, 2006
4,005
25
AL
Probably has popped head gaskets if its using that much coolant and it pressurizes the system after 10 min. Could be a cracked head too.
The system doesnt pressurize until the engine has been running for quite some time. I just drove it today, engine temp gauge will not move up past 160, drove it for 30 mins engine temp gauge never really moved. Checked upper rad. hose... dead soft. I cant see it being head gaskets.
bullfrogjohnson
Big Girl!
Nov 20, 2006
4,167
Locust, NC
If that's the case then you are loosing 1 gallon of coolant externally and it shouldn't be that hard to find the signs. Check the weep hole and the egr cooler.
9,903
149
And the rad overflow tank cap.;)
WolfLMM
Making Chips
Nov 21, 2006
4,005
25
AL
Ok I just ran the truck real hard for an hour, up rad. hose firm. Let the truck cool down for one hour and recheck the hose, still firm? Is that a good sign or a bad one.
For the life of me I cant seem to find an external leak.
WolfLMM
Making Chips
Nov 21, 2006
4,005
25
AL
it will climb to 210 if you really push the truck (drive it like a race car, wide open ect.) And yes I did make WOT runs.
PhilsLB7
Way Better Than Facebook
Jun 29, 2009
810
Tennessee
So after the WOT runs, did it drop back down to 160*?
The reason I am asking is I had a similar issue when I had to replace the hard line going to the heater core. Thought I had all the air bled out of the system but the temp gauge only when to 160*? Dealership told me I still had air in the system and to run it at WOT a few times to get the air out. After I did a few WOT runs, temp gauge went up around 210, put a little more coolant in, and no more problems. I am wondering if you are having a similar issue with air in the coolant system.
z79outlaw
793
Salem WI
Sounds normal, maybe a coolant leak by the turbo? A ripped line somewhere? If the weep hole is dry, I really think maybe it'd help to look closer into the EGR cooler, especially if your EGR isn't blocked or disabled, you could be dumping coolant into the motor everytime the EGR valve opens and you'd never know you had a leak, because other than coolant missing there'd be no visable signs.
WolfLMM
Making Chips
Nov 21, 2006
4,005
25
AL
Also when it does finally warm up, the temp guage will bounce around quite a bit, usually ending up at 160* again. Still air in the system? I have filled the burp tank several times, the system was really low so I expected to have to fill it more than once, I just hope its not actually using coolant this fast. I should know more tom. when I check again.
Thanks guys,
Wolf
Mike_S
OOPS!
Nov 18, 2009
803
40
Idaho
Does the truck loose cabin heat...as in it comes and goes somewhat related to the temp gauge? This is sounding more and more like a dislodged head gasket. The cooling system shouldn't hold more than about 15-16 LBS. Take the truck to a reputable shop and ask them to do a test for disolved hydrocarbons in the coolant, the results should tell you if the headgaskets are bad or not.
Mike_S
OOPS!
Nov 18, 2009
803
40
Idaho
Dissolved hydrocarbons? :hmm:
When a headgasket is leaking combustion gasses are forced into the cooling system and hydrocrabons (combustion gasses) disolve within the coolant. Most reputable shops have a chemical test they can do to find the amount of hydrocarbons disolve in the coolant.
