Lost engine
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
That is definitely know the top 10 of most f'd up pistons I've seen...
You should see the one out of the lb7 I bought. Problem is its in a million pieces and you can't tell its a piston..
This one is bad! Curious as if it's locked up or not?
Tothemax
xgmtech
Oct 16, 2014
607
new york
Default
If your going to wreck something do it to the best of your ability :thumb:
No still turns over
Tothemax
xgmtech
Oct 16, 2014
607
new york
Feel like I killed a unicorn
picture.php
picture.php
DMAXchris
It’s only temporary!
Apr 28, 2009
2,273
Natrona Heights PA
Man that thing got hotter than hell! Hard to believe all of that damage happened in one pass. I dont think Ive ever seen a piston melted like that.
Tothemax
xgmtech
Oct 16, 2014
607
new york
Default
Me either. What makes you think it was an injector that did that?
__________________
05 cc/sb: Trans, head studs, Moonshine, and a lift pump
03 Rc/lb: ARP studs, 100% Exergys, Empire cam, Manley rods
Reply With Quote Multi-Quote This Message Quick reply to this message
Truck would still crank would not build fuel pressure and when I got the injector out you can put air to the inlet and it comes right out the nozzle
Tothemax
xgmtech
Oct 16, 2014
607
new york
Drove it hour and a half to the track everything was good launched at maybe 12# boost cause track was cold spun off the line thinker black smoke than usual and around 3/4 down went into a bad shake and white smoke out the pipes
Tothemax
xgmtech
Oct 16, 2014
607
new york
Back from the grave!
Day 2 after bringing my money eating monster back from the dead! 75k used lbz with one new gm piston, banana pan, arp head studs, ppe race manifolds and up pipes ( thanks to Dan@ppe thanks for the great deal). Freashned up heads, rebuilt Danville 4094 stage 2r ( thanks to mark@danville can't thank that guy enough for his time and help) and 1 rebuilt 60% over injector and 7 cleaned from exergy :mad: last and least some paint and powder coat that no one can see now that it's back in the truck but hell I tried :rofl: all is well so far!
Tothemax
xgmtech
Oct 16, 2014
607
new york
Picture of the fire wall after two layers of eastwoods sound deadening mate and 1 layer off under hood boom mate. Then a coat of high temp ceramic paint. Tried to Match the gray of the rest of the engine bay close and better than bright foil.
picture.php
