LLY: Losing water somewhere, little help please
Kspen90
<<<got turbos?
Jul 14, 2011
1,433
Burleson, Tx
Buy the LISLE TOOL 22100# tool lock the flywheel and the socket is 36MM 12 point
X2 but if you can't get your hands on one or you're a cheap ass like me, put it in gear and chock the wheels really good.
EDIT: Make sure your socket is a 3/4 drive as well! You will never get it to bust loose with anything 1/2" drive. I broke two 1/2" breaker bars. (A thorsen and a snap-on)
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
If you plan to twin turbo or a huge single might want to think about tiging the center of the water pump shaft.I wasnt sure which side so i had both sides tig'ed on mine and i did another 1 for back up just in case.
catman3126
Ehhh?.... You don't say?
Jul 24, 2012
2,636
NE Oregon
LOL hows that going to work if he has an Allison? and if you have a 6 speed manual you don't need the lock tool just the socket
catman3126
Jul 24, 2012
2,636
NE Oregon
this works but eventually cracks because of the cast it is a good idea to drill and dowell pin it too the shaft also works good too.
04D_MAX
force fed
Sep 10, 2012
384
SOUTH GA
im on the super cheap side so i just pulled the inspection plate off the trans and put a pry bar in one of the holes in the fly wheel worked well for me:D
catman3126
Jul 24, 2012
2,636
NE Oregon
I have also heard of guys removing the starter and pulling a socket on the converter bolt and letting it turn till it locks against the rear housing.
