Thanks for the replies I have been busy with researching the ECM end of things and it is getting interesting. I will be going with the race cast LML pistons.
Which ring material did you use in the 300k motor? Thanks
I never had a complete engine last 300k in my line of work that I was using it in. That's rough cumulative total.. think those pistons have been in 4? Blocks.. I'd have a block die on me for X reason.. I'd get a seasoned block drop of a fleece, with the rotating assembly, have everything checked. then block bored to spec for said pistons with new rings/bearings
The longest on engine lasted was around 230-250k in which it cracked the main web, DS on #4 main web. which engine started to lose oil pressure, and I pulled the engine. That one had SS ring pack.. iirc block wore faster with SS rings.... With Moly rings wore out faster than the block.
The cylinder wall wore ~1/2 the speed with moly rings than what the SS rings did.
Per service manual piston to wall clearance limit is .010".. mahle race cast is/was .0015-.002". I set my new blocks between .002-003"..
Keep in mind my engines ran at 50-75% duty cycle on average at a ~400rwhp rating...
Avg daily driver weekend hauler might see 25-30% avg duty cycle.. which the point could easily be made lighter duty cycle substantially longer mileage life
