Long crank after lift pump install
C.bowles2
2005 lly duramax
Nov 16, 2013
489
Ohio
I installed a fass 150 the the other night and all went well but now if the truck sits a little while it abnormally cranks longer to fire up. Any ideas? If anything it should be more instant I would think. Is this normal? Btw fass makes a great install for this. Super nice for and finish. Thanks y'all
05 Chevy LLY
-Extended cab short bed 4x4
-Sinister EGR delete kit
-S&B turbo mouth piece
-Sinister intake tube
-AEM CAI
-PVC reroute
-4inch straight pipe
-Edge CTS juice with attitude plus hot tuning
-PPE race plug and ported FR fitting
-33's
andy-stevenson
Jul 7, 2013
838
Are you hopping in the truck and trying to fire it up right away or are you turning the key to accessory and letting the pump run for a couple seconds?
C.bowles2
2005 lly duramax
Nov 16, 2013
489
Ohio
Well when it did it one time I turned key right away then back to run let it build up and it still cranked a while
05 Chevy LLY
-AEM CAI
-PVC reroute
-33's
C.bowles2
2005 lly duramax
Nov 16, 2013
489
Ohio
I just did last night by stretching out the spring. Bumped it up to about 15 psi. Before it was at 6 psi. And this morning it fired right up maybe that was the problem
05 Chevy LLY
-AEM CAI
-PVC reroute
-33's
LB719
Aug 26, 2014
15
San Clemente, CA
Is it possibly sucking air somewhere? Mine was at the filter and it would crank for a few seconds before it fired, I re-lubed the seal and all was well.
Burn Down
Sep 14, 2008
7,092
Boise Idaho
My guess is it still had air in the system from install... The filters can trap air and take a little time bleed out on there own. 6 psi was more than enough to start, 15 might be getting close to causing a lope...
