Logging external thermocouples and other inputs
Sledhead
Mountain Pass Machine
Nov 29, 2008
884
BC
I'm very close to ordering a couple of Type K thermocouples for logging oil temperatures and egt using the EFI Live external inputs.
The sensors I have sourced are ungrounded 1/8 npt probes part number TC-K-1/8NPT-U-72 found here; http://www.omega.ca/shop/pptsc.asp?ref=TC-NPT
There is very little info pro or con of doing this but I have been told there may be issues. Any feedback?
Sledhead
Nov 29, 2008
884
BC
I'm planning to use those for oil temp. I'll source a different sensor or sensor/tranducer and use the 5.0V input for egt.
Mostly I'm concerned with the EFI side of it. Will the data be logged reliably?
BlkMax
743
Wasilla, AK
Yep. I have done it both ways. I have on of these: http://www.aeroforcetech.com/products_sensors_egt.html from Aeroforce for one EGT input where I split the 0-5v output signal between the gauge and EFI. I also have another thermocouple that I put in the other manifold that I run straight into the V2 EGT input. Both have been successfully logged. You do have to do some setup in one of the scan files....sorry, I can't remember which one right now... at work.
turbo_bu
199
7
Central IL
as long as they are ungrounded, your good. That has been my experiece with logging with the V2 Flashscan.
As was said, you will need to do a little editing of the config.txt file that gets uploaded into the V2 so it can "see" that you are logging those extra thermocouples.
