Lockup
coker6303
Keep Calm and Chive On!!
Aug 6, 2009
2,484
40
Houston, TX
Anyone notice lockup issues with the precision ML converter? Doing boosted 4wd launches I'm not seeting lockup until 4th.
Looks like I may need the magic box...
Sent from my ADR6400L using Tapatalk
coker6303
Aug 6, 2009
2,484
40
Houston, TX
Seems to do it in both tow haul and normal. Sometimes it hits right, but most of the time it doesn't lockup until 4th
I didn't think I would have this issue with the ml. Thought it was mostly high stall converters
blackdirtymax
Apr 15, 2010
825
augusta, ga
It has to do with power output of the motor and turbine speed . Just cause it locks in one truck , doesn't necessarily mean it will do it in another , they might be makin more power than you lol
Built motor , duel fuelers , 60's overs , gtx4202r
13,736
806
My ML locks up fine. Maybe you need to talk to Mike before you buy a lock up controller.
I see you have a lockup controller.
RedDmaxLBZ07 Signature said:
2007 Chevrolet CC/SB LBZ
EFI Live-Tuned by Rob Coddens
SunCoast 6pac
Allseason EGR Delete and Y-Bridge
BT DieselWorks Lock Up/Unlock Controller
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
The 6 speeds seem to have a fair bit of trouble locking up as the power grows , but a few simple tests can check to make sure the converter is stalling at the right speed , brake stall the truck up and see what rpm its pulling through the brakes .
Sledheadxp800r
That was only my tow tune
Dec 13, 2010
1,151
39
Are you asking if it is fixed or saying for Ben to get the problem fixed on the new one ?
I don't want to speak for anyone but the way I read the funks post was if he gets Bens new controller his lockup issues will be solved.
