I run Ben's (bt diesel works) box on mine and have a good results. Street or strip it's great. I just leave it in auto for the most part.
Lookin at gettin a lockup box for my 05 duramax with the 5 speed whats your opinions
http://dirtyhookerdiesel.com my favorite switch on the market is sold by DHD.
I bought it used and had him update it, turn around time was 2 weeks between me sending mine in and him sending it back. Talked to him on the phone, he is a really busy guy so patients is key.
There are 2 codes that come up after installed but it's because of how you wire the box in, they are ghost codes basically they do not affect anything whatsoever.
Why not just run it T/H?
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Please correct me if I'm wrong since I've mostly only messed with the 5 speed and haven't messed with the lockup boxes but doesn't line pressure drop any time the TC locks unless the knockdown valve has been modified, ball removed and you have replaced the spring? Isn't that the only way to eliminate pressure drop. unless we are talking about the LML where, I believe, the TCM has partial control of line pressure?Drops line pressure.
Couldn't you swap the tables in the TCM with EFILive to start up in T/H and have the same effect with a built trans?WOT, the shift and TC lock up pattern is the same between either mode.
I run the stock TCM setup with modded lock up tables. works like a charm every time and no extra buttons.
