Lock up box and tps error
N2BRK
2,054
371
I bought the box used from a member here a few weeks ago. I love it! But this morning I popped a P2138. I reset it and nothing came back yet. Any ideas on this?
Thanks!!
Wally
N2BRK
2,054
371
Thanks. Yep it's the 6 speed BT box. My truck flashed an Engine Power Reduced message at me this morning, which prompted me checking codes. Most connections are soldered, but I did use tap ins on the TPS and ground to the BCM.
N2BRK
2,054
371
It's the first hiccup since I installed a few weeks ago. I'm away from home on business until Sunday, so I can't do much right now.
N2BRK
2,054
371
Just fired up again. First since yesterday morning. Threw the code again right away. Damn
N2BRK
2,054
371
Interesting. Keeps throwing it. Box not coming on either. I'd better check fuse and connections when I get home
N2BRK
2,054
371
Start the truck and before I make it a block or so, it throws. I did not try to arm. Last time I noticed no light, so I tried to arm and nothing happened.
N2BRK
2,054
371
Temps are so low lately, that the trans would be too cold to arm even if I tried
N2BRK
2,054
371
Uh oh. Now it's every time that I stop. I made it through my appointments tonight with one hand on the wheel and one on the clear dtc codes button :thumb: hope to make it home.
N2BRK
2,054
371
I decided to try for home tonight instead of tomorrow. Each stop it limped. Anything more than light throttle it limped. At least I'm home. Hopefully I can find something tomorrow.
N2BRK
2,054
371
Unugged it all. P2761. Going to just unplug controller next I guess
N2BRK
2,054
371
Quick disconnect got loose. Just took a very sideways test drive :woott:
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
10
Wyoming
Glad you got it fixed!
Sorry I didnt see this until now, I was away all weekend.
9 times out of 10, its wiring issues with these modules. I always tell people to solder if possible.
Ben
