Let me start off by saying I don't know enough about this topic to know what I'm getting Into.. so I don't want anyone to think Iim trying to prove anyone wrong here. I'm simply making sure I won't run into issues when my engine gets assembled.
I've got a set of 16:1 .020" over oval bowl pistons with no valve reliefs for my build.
I picked up a "stage 1" alternate firing cam as well that states no valve reliefs are needed to run this cam. I got looking at the spec sheet that came with my cam vs what a stock cam measures and it appears this cam has .066" more lift on the intake than a stock cam. I just want to be sure my combination will work together without issue.
Measuring a stock lbz piston to my oval bowl, it appears the oval bowls are roughly .010" shorter from the top of the wrist pin hole to the top of the piston (1.271") and the lbz pistons measures 1.281". I would assume a stock lly piston is the same height wise as the lbz piston..
At how much additional lift over stock are valve reliefs needed?
From what I can tell, I should be good to go..right?
