Cause I screwed up the link To much softball this weekend
:angel::secret:
Sorry to hear about your problems Jeff. Any idea what is going on? I'd be glad to help if there's anything I can do.It run a 12.31 at 110.51. I run in the 11's with a stock motor and $300 worth of NOS parts I had in the shop! The truck is heavy(more than normal) 6800 lbs. because it still has the big CNG tank in the back. I also run on 33" AT tires because the Proxies will not fit in the trailer without changing the front. I just thought it still would trap around 120 or so. Jeff
Brayden boost or making boost doesn't seem to be a problem. It just acts like theres no fuel. It acts like it did before I put the daul CP3 on it. I'm going to EEP to dyno tomarrow so maybe I can try a few things. I will pull the injectors this winter but I just figured Pat run fast with stock injectors I should be able to also, But maybe not it is me. Jeff
I'm not sure Ed. That could be the trouble. I didn't make the dyno today but it looks like wed. now. I need to get some info to log so I can get some help. Jeff
