Lmm wont start
smokinlmm
Jan 22, 2011
19
The key on my 07.5 got left on batteries went dead new batteries in and trucks actin weird its gota 3 pattern ding all the time key in it or not turn the key on dash lights come on none of the gauges move wont turn over or anything guy that tunes for me said it usually does it to him when he flashes it any ideas thanks
1,943
Moved to Electronics section. No idea on what you did except it sounds like an ECM/BCM issue. You may need a Tech2 to see if they are communicating (or even working).
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,214
364
At Da Beach
Your the 1 that got my screen name! This is the only forum I don't have it on. Haha
Your security system is acting up. Your stereo factory or aftermarket?
BLACKMAX1
WAY2EVL
Jul 10, 2013
555
VA beach
Are the gear selections illuminating in the cluster when the key is in the RUN position, and have you checked to see if you blew any fuses? It sounds like you don't have any communication with the ECM.
BLACKMAX1
WAY2EVL
Jul 10, 2013
555
VA beach
If fuses are good and the bail connectors on top of the motor are good then it is most likely your BCM or ECM are bad or your ECM is not communicating.
