LMM twin build....pics inside
DuramaxPowered
Pushing my luck....
Jan 27, 2008
791
41
Monroe, MI
The LMM twin build is underway...... DMAXVAZ and me got quite a bit of fabrication done today. All the EGR and stock parts are off of the motor and I have the pass side LB7 up-pipe on. The turbo mount and hotpipe and tacked up and so far the progress has been smooth. Big thanks to DMAXVAZ for all the help!!!
SIKDMAX
Highway Burnouts!
Sep 14, 2007
4,698
Central Coast, Cali
www.sikdmax.com
Interesting spot for the fuel filter. Not sure what Im going to do with mine yet.
How is the big charger mounted? Whered you run brackets off of etc.
What are you going to do about coolant overflow? How about the 2nd batt?
DuramaxPowered
Pushing my luck....
Jan 27, 2008
791
41
Monroe, MI
Big charger has a bracket off of the block. There is a bracket that holds the fan shroud that has 2 large bolts and the bracket bolt up there.
Not sure yet on the coolant tank.......
2nd battery is already relocated to the framerail.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
I think you will be more than satisfied with 45% over. I dont think people realize just how big 60+% is. ;)
I tried running a little 1900us 18* timing tune in my truck once just to see how it would feel with my "small" 35% injectors, and it definitely felt faster than a 3000us 27* timing tune with stock injectors.
JMO...
ben
