That's a good-looking picture but can I take the converter with the motor since it is locked up I can't get to all the bolts
Correct..
It might be simpler to pull the transmission out. Then pull the engine.. TC ads 6-8" of length to the engine which you only have ~2-3" to work with.
TC has to be removed so the lower 2 bolts that hold the upper oil pan to the back plate..
I'd torch the flexplate around the bolt holes once out, To remove the TC.
One question is it locked in both directions?
