LMM: LMM Falls on its face, then comes back when I let off and get back into it
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
My LBZ used to do the same thing till I fixed without using a lift pump, so use a lift pump, I'll be installing one someday...
610
Low rail pressure. More diagnostics would be required to tell you what is causing it.
This..
Swap fuel filter, could've got a dirt tank of fuel doesnt take much to plug a stock filter with no lift pump
Put back to stock tube
Or
Get a lift pump
Have through a p0087 code yet?
portmax29
Nov 20, 2010
Mine would do the same, I installed the race plug on my 02 and fixed the issue. Granted i already had the lift pump and was running a higher tune than you are.
