I have a 2008 LMM engine core to build to about 650-700hp daily driver but I'm putting it in my 2004 Chevy 2500hd now I called fleece and the can build it but it's a lot of change with injectors wiring and a couple other things I want to know would it better to use lbz wiring or lb7 wiring here build tell me what guys think
CS R
Date
Estimate #
Year/Make
Caleb
11/26/2014
3804
Estimate
Description
Qty
U/M
Rate
Total
Carillo H Beam Rods
2,650.00
2,650.00T
Mahle Motorsports Cast Performance Piston, No Reliefs
1,795.00
1,795.00T
ARP Main Studs for GM Duramax
262.38
262.38T
ATI SuperDamper
502.50
502.50T
Suncoast Billet Flexplate for GM Duramax Please Specify LB7/LLY or LBZ/LMM
709.00
709.00T
Replacement Duramax Oil Cooler
398.88
398.88T
Replacement Duramax Oil Pump
237.90
237.90T
Keyed Remanufactured NAPA Water Pump
149.65
149.65T
Duramax Overhaul Gasket Kit
815.06
815.06T
Clevite H Series Main Bearings .003
156.19
156.19T
Clevite H Series Rod Bearing
237.71
237.71T
Clevite Duramax Thrust Bearings
55.63
55.63T
Hot Tank Engine Block
125.00
125.00
Align Hone Main Bearing Bore
200.00
200.00
Rebore Cylinders
200.00
200.00
Torque Plate Hone Cylinders
400.00
400.00
Deck Engine Block
200.00
200.00
Balance Duramax Rotating Assembly. -Balancing includes Heavy Metals added internally to the crank in order to lesson rotating mass at the balancer & flywheel, alleviating some stress on the crank between #1 & #2 crank journal.(Must be used with ATI Balancer 'w' Custom weight & Suncoast Billet Flywheel.)
1,562.50
1,562.50T
Magnaflux Crankshaft
67.50
67.50
Polish Duramax Crankshaft
90.00
90.00
Key Duramax Crankshaft
196.92
196.92T
Key Duramax Camshaft
135.08
135.08T
ARP Duramax Engine Head Stud Kit
685.81
685.81T
GM Duramax OEM C Head Gasket
149.10
298.20T
Hot Tank Usage
75.00
75.00T
Resurface Duramax Cylinder Head
145.00
290.00
Pressure Check Cylinder Head
62.50
125.00
Install Valve Seals
32
2.10
67.20
Name / Address
Cedrick Mathis
46 Sunset Lane Birmingham, AL 35215
CS R
Date
Estimate #
Year/Make
Caleb
11/26/2014
3804
Estimate
Description
Qty
U/M
Rate
Total
Duramax Valve Guide Removal and Re-installation (Pair)
352.12
352.12
Duramax Cylinder Head Competition Valve Job & Blend (Pair)
562.50
562.50
Consumables (Brake Wash, RTV, Hi Tack, Paint, etc.)
105.00
105.00T
High Performance Engine Assembly Labor
20
140.00
2,800.00
16,507.73
Fuel Injectors & Injection Pump Upgrade
LBZ/LMM Duramax PowerFlo 750 CP3 - 10mm Stroker Injection Pump (FPR must be scaled appropriately when installed in a LB7 or LLY )
1,895.00
1,895.00T
2004.5-2005 LLY New Bosch Injector 'w' New 100HP Nozzle
563.00
4,504.00T
Injector Core Charge
100.00
100.00
2001-2007 Classic GM AirDog II 165 GPH (A5SABC109)
776.00
776.00T
Turbocharger & Installation Kit
2004.5-2007 Classic LLY/LBZ Duramax FPE Billet S363 & Installation Kit Includes:
-FPE Billet S363/68 T4 IWG 'w' FPE Duramax V-Band Turbo Inlet
-T4 Pedestal
-HX40 Downpipe 'w' Clamps
-Driverside Transmission Dip Stick Tube -S300 Duramax Turbo Installation Kit -Duramax Turbo Thermostat Coolant Delete Plug
3,591.49
3,591.49T
Tuning
EFILive AutoCal with Custom DSP5 ECM Tune - Late LLY Duramax (2004.5-2005)
849.00T
LLY DSP5 Switch
49.95
49.95T
ESTIMATED FREIGHT CHARGE
750.00
750.00
Indiana Sales Tax
7.00%
1,588.57
Total
$30,611.74
CS R
Date
Estimate #
Year/Make
Caleb
11/26/2014
3804
Estimate
Description
Qty
U/M
Rate
Total
Carillo H Beam Rods
2,650.00
2,650.00T
1,795.00
1,795.00T
262.38
262.38T
ATI SuperDamper
502.50
502.50T
709.00
709.00T
398.88
398.88T
237.90
237.90T
149.65
149.65T
815.06
815.06T
156.19
156.19T
237.71
237.71T
55.63
55.63T
125.00
125.00
200.00
200.00
Rebore Cylinders
200.00
200.00
400.00
400.00
Deck Engine Block
200.00
200.00
1,562.50
1,562.50T
67.50
67.50
90.00
90.00
196.92
196.92T
135.08
135.08T
685.81
685.81T
149.10
298.20T
Hot Tank Usage
75.00
75.00T
145.00
290.00
62.50
125.00
Install Valve Seals
32
2.10
67.20
Name / Address
Cedrick Mathis
CS R
Date
Estimate #
Year/Make
Caleb
11/26/2014
3804
Estimate
Description
Qty
U/M
Rate
Total
352.12
352.12
562.50
562.50
105.00
105.00T
20
140.00
2,800.00
16,507.73
1,895.00
1,895.00T
563.00
4,504.00T
100.00
100.00
776.00
776.00T
-T4 Pedestal
3,591.49
3,591.49T
Tuning
849.00T
LLY DSP5 Switch
49.95
49.95T
750.00
750.00
Indiana Sales Tax
7.00%
1,588.57
Total
$30,611.74
