LMM: LMM Attempts Crank but wont. Think VATS or *83 OS. HELP!
SIKDMAX
Highway Burnouts!
Sep 14, 2007
4,698
37
Central Coast, Cali
www.sikdmax.com
How long has it sat? Could be a bad battery. That's common lately in every issue seems like I have been dealing with lately. Try swapping out with a good known battery. It's an easy test anyway. Maybe also try that battery in the truck you swap with for a better test. Worth a shot. Doesn't sound like vats to me. How ever go to the 94 os because you will get the vats issue at some point and may not have efi with you.
Brand new Optima Red Top. First thing I eliminated.
Still havent gotten to it.... I will today though. I can tell Im real damn close.
coker6303
Keep Calm and Chive On!!
Aug 6, 2009
2,484
40
Houston, TX
I can't leave VATS on with my truck, for some reason it will click to turn over but do nothing else. It did this one day after I rotated my tires, I just loaded the tune without it. Been fine since!
sent via rooted DroiD
SS4.7 1.25GHz
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
Put a volt meter on the batt.
See how many volts are there
attempt to crank, watch the volt meter - How many volts does it show while cranking (key in start position)?
