LMM: LMM 900-1000hp build
624
Whats the main difference between Finger's pistons and the new low compression Mahle with graphite skirt coating and valve reliefs? I liked the Mahle's, holding well at 650+ and extended time over 1500f.
Only suggestion I would add is drill out the oiler tips, helps piston cooling and gives extra lube to wrist pins.
Where is that test?
kidturbo
Piston Tester
Jul 21, 2010
2,553
1,401
Somewhere On The Ohio
www.marinemods.us
My data is on the water with the most hours logged to date in a marine setting. Over 300hrs and still going strong, with another member now.. WOT time measured in minutes, max EGT 1650 without failure. All well documented online, alnong with the pile of cracked and melted stock LLY they replaced.
http://www.duramaxdiesels.com/forum/showthread.php?p=675570
So just wondered what is the actual difference, design is verrrrry similar. Maybe the exta oil helps?
