LML LML with EFI Delete and Mike L Transmission
dmax711
Mar 4, 2011
1,057
concord, north carolina
Im gonna toss bens pressure box on mine and see how long she lasts, I have not built an lml trans yet but as far as I know just more clutches and pressure is what they need. The trans in my old triple truck used a few lml goodies from George and it was the best feeling trans I've felt.
15,681
What did you get mike to do? What converter you go with? You do just clutches and the new revtec spring kit or are you running a pressure box from Ben? I'm in the process of figuring out which way to go with mine and I'm looking for insight from others who have built theirs. I spoke with Mike earlier his week and he told me to call George at Suncoast, I'm just waiting to hear back from him to see what he is gonna put together for me...
Revmax uses my spring kit.
Wfodiesel
Oct 16, 2014
20
Well mike I'm new as far as Allison's go, I'm wanting my truck around 500 to 550 hp. Would u recommend a built trans or would a few of your items make my trans more reliable without being completely built?
15,681
The LML Allison does not like anything over 800 ft lb of torque. Ben's black box will make the LML trans work like a 2010 or earlier. It is capable of 250 psi static. It will help. Converter clutch will break up at that pressure.
Just remember that when you build the trans you MUST use my pressure system in the pump and valve body and you CAN NOT use Ben's box if you do.
catmenace
255
Mike installed the Goeren R Conv, Pump & Valve Body Upgrade, New Clutches. It's good for 700 to 750 HP. I am not planning on more then 650 HP. No Black box required for my type of driving. It runs fantastic!!!!
