LML Twins and Opinions
FROGMAN524
613
I meant to stay stock when I bought this one too. Little late for that now lol.
Dm23
400
125
Socal
“We all wanted to stay somewhat stock” that never happens lol Please post pictures of the progress :thumb: I plan on going the same route with compounds. The s475 over the 65mm Danville.
FROGMAN524
613
I will post pics of everything once it shows up and is installed. Thinking next week or the following when I get most of the good stuff.
FROGMAN524
613
Just received my PPE deep oil pan and my PPE deep trans pan and I also had the intellihaul three camera system installed on the truck as well.
S Phinney
4,008
Quncy, Fl
I haven’t had any problems with the stock turbo in compounds so far. Boost stays pretty consistent makes about 62 psi boost runs very good. My tuners does a great job!
Dm23
400
125
Socal
Frogman, with that cp3 conversion do you plan on doing the fuel filter delete, or are you keeping the factory fuel filter intact? and do you plan on doing the install yourself?
Josh154
1,220
85
Sioux Falls SD
I just did my cp3 conversion and removed the factory filter and all those lines. Pulled the 9th injector out as well. Ran 1/2” hose straight from cp3 to quick connect by turbo. Made it so much more simple, it will pull through fass as well if fass fails.
M.A.M.
429
Ohio
I’m pretty sure he’ll need to remove the factory filter head if he’s going with compounds.
Dm23
400
125
Socal
I thought the factory location for the fuel filter. Was just moved around a bit for twins. ? So with that hsp kit you had to remove the filter so everything would fit ?
13,736
806
It isn’t a twin kit, but here is an SDP y bridge and CP3 conversion we are wrapping up in the shop. This color really pops on this black truck. I can’t wait to get it out in the sunlight and see how it really looks.
attachment.php
