Hello all,
It's been a while since I've asked some questions on here but I'd like to see what everyone thinks I need or should add to my upcoming "build."
Recently I lifted my 2016 LML CCSB 4x4, which is tuned and deleted by MotorOps via Autocal and DSP5 switch, Flo Pro 5" exhaust with 14" muffler and 30" FTE resonator and S&B intake. For the lift I installed a Cognito 4-6, Yukon 4.11s, King Shocks, AirLift bags, Airlift compressor, Amp power steps, Amp side steps for the bed, RoyaltyCore grille, PPE tie rods, PISK kit, trail ready wheels in 17x8.5, Toyo MTs in 35x12.50R17, cognito front driveline, Rigid 30" bar behind grille, Rigid duallys in front and rear bumpers.
Now, I'm upping the performance. I've ordered the following:
WCFab twin kit with billet S480/1.32AR over a Stealth 64/67 hybrid valley turbo
Exergy 12mm CP3 and conversion
Exergy 100% injectors
Banks Techni-cooler
WCFab hot and cold side pipes - 3" with 3-3.5" reducers for intercooler
HSP billet manifolds and 2" SS up pipes
WCFab turbo blankets for both
EDGE EAS 0-100 psi boost sensor for charge pipe
Tuning will be by MotorOps again
Does anybody think I'll need valves springs or push rods or a damper or anything else like head studs? Truck is and will be daily driven, not raced more than a few times a year at the most, not sled pulled and will be used for towing heavy loads multiple times per year in the Phoenix heat. Also ordered up a deep pan for the trans, which was built by Mike L last year, and all new filters for it and the rest of the system.
Thanks,
Frogman524
Banks Techni-cooler
Thanks,
Frogman524
