the pistons are different, they have a different ring package, and bowl designed after the piezo style injectors, rail psi is up too i think it's 29.5k
bore and stroke is the same, cam is different,rods/ mains have better bolts
fuel system is all made around the injectors, turbo has 5 sensors on it, oil temp, coolant temp, turbin speed, exhaust psi, and boost i think...
Rear thrust, is better material, oil gallies are better, and jets are bigger.
if i remember more i'll post it up.
