Never had this come up before and of course it happens 3 hours from home with the trailer. It sets immediately after start up and also sets again while driving immediately after clearing the code. I cleaned the MAF after limping the truck home and it didn't change a thing. I didn't see any obvious wear on the harness, but I didn't check every inch of it back to the ECM either. Was fine when I parked it last, and showed up as soon as I started to the truck to leave.
Is there a way to check the MAF for continuity/resistance to see if it's in range and the pin out of the harness? I can't seem to find any info on doing that and getting an OEM AC Delco MAF is expensive. No local parts store can even get an OEM one so it's a dealer only thing if they can even get it. I ordered a delphi unit (the only one they could get) but if there is a way to rule out the wiring in the truck or pinpoint the issue with the sensor it would be way better than spending the money throwing parts at it.
