2011 Duramax
So bought a truck off auction and someone had started to dig into it.
Someone pulled the regulator off the top of the injection pump so i got a new one, put it together, still no start. will start off ether, but then die due to no fuel.
Installed a new injection pump from GM, now the truck will start, but only with ether. shut it off and crank to start right away, nothing, 500psi max pressure cranking, 65 psi KOEO Starts and idles smooth. while driving it is a little under powered and says it is cleaning dpf. kicks engine code for low rail pressure. has one bad injector according to balance rates, i do not have an injector on hand so i capped it off and still no start.
Does the ecm need reflashed/programmed after pump install? probably not.
I do sometime here buzzing from the regulator on top of the pump with the key on, and it wont stop unitl i pull ecm relay.
going to do a bottle test and see how much it is returning next, just thought it was wierd that the fpr buzzed sometimes.
Is there a fuel return valve that could go bad on these also to cause not start
Sorry so long but looking for some insight
