Looks like the map is moving and the baro is staying the same. Are you just revving the truck in park? You need to drive it while scanning, otherwise you won't see much frp or tell if it wants to build boost.
Out of all things when I went change the air filter and check the maf the intake tube was barely on the to where you couldn’t see it off or loose, it runs great now. Thanks for all y’all’s help I truly do appreciate it
