LML MBRP Downpipe install:
Test vehicle: 2013 GMC LML with all factory emissions in place.
To recap our previous testing please check out our Project LML blog http://atptrucks.com/blog/project-lml-duramax/
The downpipe manufacture HP claim is 21hp and 24ft lbs. We will see how this piggy backs on the current mods with HP tune and the S & B intake.
I can tell you the downpipe install is not for the faint of heart. The install is much easier if done in conjunction with a transmission/converter install. Having the transmission out of the way really speeds things up and is much easier on the knuckles and the frustration level.
Even with the transmission out of the way, the install still took about 3 hours. This wasn’t straight time as I dealt with a few interruptions along the way, but a good baseline none-the-less. If the transmission is in the truck, I’m estimating 4-6 hour install and some bloody knuckles. Everything bolted up fine without having to modify anything on the truck and no special tools needed.
I don't have back to back, same day numbers but I used same load and same SAE correction factor.
Dyno'd 500.66 RWHP with the DPF system showing 40 soot grams (basically ready for a regen). This shows a gain of approx. 25hp. I was a bit skeptical because the SAE correction factor showed a different percentage as the runs were during different days so I ran the uncorrected numbers and the downpipe showed a 16hp gain. The dyno graphs show the info on the different conditions of the runs. Personally I’m leaning towards a 20HP gain.
So truck mods to date to hit this 500hp number; MikeL trans, ATP tuning, S & B dry intake, MBRP downpipe. The next test will be an AirDog 4G lift pump. With the rail pressure dropping under load, I feel this will be a nice addition to HP and longevity of the fuel system. Stay tuned.
I tested at the track before the lift pump install. The same tune that made 500HP without a lift pump didn't perform on the 1/4 mile. Dropped rail bad about 3rd gear and didn't recover for a while running 14.2's with 2.0 60' times.
I installed a tow tune with mild pulse and the truck went 13.8 with the same 60' times.
So 500hp on the dyno before lift pump really wasn't a 500hp tune on the street under full load conditions. I feel the lift pump will be a much better addition for performance driving conditions compared to short dyno pulls of a few seconds. So IMHO the lift pump is the best bang for the buck that we have tested to date (besides tuning that is)
The regens with this tune are not too much different than stock. I'm around 350 miles in city driving and bumping up to the 700 mile limit on all highway driving. DEF usage seems lower, I'm not sure why. Winter fuel increases regens for sure. I averaged 18.2 mpg on a trip to Oregon for racing and that included 10 passes on the 1/4 mile and about 20% city driving (before the lift pump install).
I will say when I bought this truck stock, I wouldn't even drive it as the dead peddle was so bad.
Now, I can honestly say this is the most fun duramax I have owned for street driving and I've owned some good ones. The truck spools amazingly and has a very quick feel for how heavy it is.
I do not recommend buying a LML and think you are going to build a 10 or 11 second truck as the efi live tuning is no where close to tuning a highly modded LML. Still way to many hidden limiters and tables that do nothing. But for a really fun daily driver, the LML is a blast. with tuning and a few bolt ons.
Updates at all?
