LML deleted problems
S Phinney
4,008
Quncy, Fl
For sure let us know. There are so many issues created by different faults and they all appear the same but are not.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
We have tuned hundreds and hundreds of these, every once in a while one has an issue and it makes little sense when these occur.
I looked at and compared the file to all the others and it is set up the same as I always set them up.
When a shop/customer does 5 with no issue and one has an issue we will definitely look into it for them.
We do not leave our shops or customers hanging.
And this is why I haven't ventured into LML's. I know dam good and well if they give somebody as good as you trouble, that I don't stand a chnace with them. It seems all you read about LML's is how nothing in them makes any sense, how ghosts in the machine pop up for no reason, and they have been a challenge to say the least.
mdpdiesel
Nov 30, 2015
I think on those model you have torque limiter set to 300nm in 4WD LO. B1152 B1153 B1154 B1155 B1156 B1157. Check also B1192 for limp mode. Did you have remove egr also ?
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,224
370
At Da Beach
LML says it all. Mines been a BIOTICH several times...:mad:
If the new tune doesn't work reflash it with global, it's brought mine back several times... Haha...
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
Couldn't get together this weekend with him between family stuff and work. I'll keep you guys posted.
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
Got with huffy Saturday and got it fixed. Updated tune from Tony took care of it.
Thanks Tony!
scramHD
112
Tx / MS / AL / MEX / FL
f n g.........no. iIm saving you future posts, possibly hundreds, that will flood the forum by you stating "ecm locked, truck wont start after deletes, loosing coolant, abs, stabilitrack warnings, check engine, and lastly P0700.......and I quote " While giving it some throttle on my new tune, all of a sudden it slammed out of gear and rev'd real high, then seemed like all I had was 3rd gear....I had to pull over and check everything out...everything seems ok. Anybody know what happened?"
In fact this condition is very very rare. No one here has a clue as to what may have happened. There are no deletes available. All used up.
jwrkansas
117
There's a 4 low speed limiter table that if adjusted incorrectly will limit speed. I doubt Tony would've overlooked it though
