If you have an extended cab or reg cab LML, odds are very high that you have an isolated centerlink. Do yourself a favor and find a salvageyard centerlink out of a crew cab LML to do away with the rubber isolator and firm up the steering/launches. I paid $80 each for the last 2 I bought with good tierods.
The large eye pictured below for the pitman arm is a rubber isolator that will have quite a bit of slack after some use. The isolator pictured has 160k miles on it and is severely worn. It is designed to cusion the bump steer, etc. and does a good job at it. IMO, even when going to cognito braces with that style centerlink, it will still have play in the centerlink but it will prevent it from rolling on launches for the most part. The DHD brace will not work at all with it.
Sent from my SM-G930V using Tapatalk
