LML bottom end
Hawk 40
Oct 30, 2014
172
Sarasota
Does anyone know if I can put LBZ heads/injectors, fuel components, computer and wiring on LML short blocks?
meshanic
All In Trucks
Dec 9, 2010
436
West Texas
Yeah it works. Short blocks are pretty much the same except the oil feed for the stock turbo is moved. The LML back cover is different too but you can use the LBZ back cover.
1,868
I would imagine you'd have to swap the front cover and possibly the reluctor assembly, too.
Hawk 40
Oct 30, 2014
172
Sarasota
1,868
Looks like it's time to start swapping out parts. I need the LBZ components up top because the LML's are too limited on stand alone set ups needed for marine use. What about the stock LML turbo, I should be able to keep that right?
That I am not sure of. You would want to contact vendors MarkBroviak or YellowChevy and ask them, as they know much about the different Dmax turbos.
Oregon, years. I dont think there's any way to find out totals sold.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
10
Wyoming
Turbo's will interchange just fine. Im not 100% sure if you can use the same vane position sensor though, or if you'll need to swap to an LBZ vane position sensor.
Ben
