Lly turbo
SteveFord
What's Next?
May 8, 2008
1,317
Iowa
Anyone done any testing with an lly turbo on how much boost it will make with the vanes all the way open? Just curious as the way i have the vanes tuned just want to know how much boost the 4202 is making. If someone knows I can figured it close enough. Thanks!
SteveFord
What's Next?
May 8, 2008
1,317
Iowa
No drive pressure guage and have no plans really to get one. Opening them up from testing by going by my egts is telling me its breathing better and the 4202 is producing more boost this way. What I'm trying to do is make the 4202 do most of the work at wot at a certain rpm and boost as the vanes open up all the way allowing as much exhaust as possible to go by the stocker and drive the big charger. Drivabilty of twins but at wot act more like a big single as much as I can.
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
If you are running the stock VNT charger a drive psi gauge is a must for tuning in my opinion.
I've seen 100+psi of drive on 40psi of boost. Scary numbers.
SteveFord
What's Next?
May 8, 2008
1,317
Iowa
I see what your saying but there is no way a stock vvt can make enough boost with the vanes all the way open. Most guys see really good drive pressures with twins until they hit higher rpms.
SteveFord
What's Next?
May 8, 2008
1,317
Iowa
So if I'm holding 50psi of boost in 4th and the stock vanes are at zero percent all the way open the stock charger is making 40psi and the 4202 is making 10psi? If your right about the percentages.
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
I'd guess something is limiting your vanes from going to 0%. You wouldn't ever be able to make that much boost with the vanes at 0%.
SteveFord
What's Next?
May 8, 2008
1,317
Iowa
It makes right at 50psi with my twins setup and holds it in 4th and my vanes are at 0% totally open. Logs show 0% so it is possible.
SteveFord
What's Next?
May 8, 2008
1,317
Iowa
To be honest I have no idea. Jason Otto bought this kit new and with a built motor 60%overs and dual pumps with a stock lbz turbo he made over 850rwhp with this kit on his lly at Hucks dyno. It's a gated kit.
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
Hypothetically speaking...if the turbo was tight enough, and you were essentially bypassing the stock charger, I guess it would act like a big laggy single.
Is that what you were asking?
SteveFord
What's Next?
May 8, 2008
1,317
Iowa
In a way yes! It acts like twins should driving around and towing. I'm trying to make sure it still spools fast enough from a dig but then the stocker opens up and the big charger does the majority of the work. They way I have it now is if everything is right as far as boost, at 2600 the vanes open up.
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
Ideally, a compound setup works where the small charger does all the work down low and then gradually gets aided by the larger charger. There is a reason the big charger in a compound setup is called the 'low pressure charger,' because it flows big CFM at low psi.
SteveFord
What's Next?
May 8, 2008
1,317
Iowa
Understand that. Has anyone tried to do what I'm doing to see if that works also? Thats the reason I was wondering what an lly turbo makes for boost with the vanes fully open.
D-MAX Mafia
Hood down, smoke up!
Nov 4, 2009
1,112
13
Phoenix
I have been wondering the same thing. If I was to build a tune for a compound setup I would open up the vanes as the big charger lit up.
FrankenMax
Mar 30, 2011
265
Round mountain NV
This is what I'm seeing on a very mild tune.
60psi boost
28psi boost out of the s480
100 psi drive pressure could be more idk it only go's to a 100.
Idk if that help you but it can give you something to think about.
SteveFord
What's Next?
May 8, 2008
1,317
Iowa
60psi boost
Thats a ton of drive pressure but then again your also seeing 60psi on a mild tune. Other guys I know that have tested drive with the mpi kits see close to a 1:1-1.5 but as they get above 3400rpm it starts to jump up. It's tuff to compare a totally different kit from another and tuning that isn't the same also.
FrankenMax
Mar 30, 2011
265
Round mountain NV
I've been told that it's high but the truck is really responsive it builds boost incredibly fast like Instantly but I think that's due to the race cover on the s480.
MarkBroviak
DMax Junkie
2,151
551
Danville Indiana
Yes Steve, you are going about it the right way. It will depend on the amount of fuel in the tuning also but I run my vanes at 0% above 2600rpms and I have 56psi boost total and 65psi drive until I get upstairs and then the drive will climb to 80psi at 4500rpms but I can back that down with the gate.
