Lly rear diff breather question 11.5 AAM
C.bowles2
2005 lly duramax
Nov 16, 2013
489
Ohio
I'm wondering how one goes about checking to see if the rear axle breather vent is functioning properly. I pulled the breather hose off the diff and ran air through it and it breaths but what about the nipple going into the differential? How do I check if that is clear. I blew a small amount if air into it and it didn't seem right. Is it a kne way deal? Thanks
3,724
292
What makes you think it isn't working?
I looked through my GM service manuals for a bit, but couldn't find anything indicating if there is a check valve. I think it is just a nipple.
C.bowles2
2005 lly duramax
Nov 16, 2013
489
Ohio
Yea a nipple on the actual differential and a hose going up to a cap. Breathable cap btw. Obviously lol but I replaced a leaking pinion seal and it's still leaking. The pinion yoke might be to blame there. But I wanted tk make sure the vent wasn't clogged.
C.bowles2
2005 lly duramax
Nov 16, 2013
489
Ohio
Oh I see what your saying, you check to see if it was free flowing, with the amount of air I put in I doubt it filled it with air. It seems plugged
13,686
736
Pull the fill plug and see if air comes out when you blow through the hose.
C.bowles2
2005 lly duramax
Nov 16, 2013
489
Ohio
Yea I just thought of that haha. I will tomorrow and see what I get. If that isn't the problem do they have sleeves for these rear yokes?
1,837
Had an issue with axle seals blowing out....found my breather tube had slacked down a bit and had gotten stopped up with lube. Fixed that and no more blown seals.
