Hey guys, finally saved some money and found out what happened to my motor. Number 4 piston spun a bearing and the piston hit the valves. So I am going to get a valve job done for sure. Then at minimum replace that piston, should I replace all 8 Pistons. The moto has 190k. I am doing all 8 piston rings as well. I am not sure about the crank yet or condition of the rods. I know Duramax in different years did stronger rods crank etc. I am just seeing what you guys think I should do on it. Since I'm doing all this work I am keeping the truck for a long time. I just tow a camper and do have efi live and other bolt ons, stock transmission. I just want it to last and not have to do this again. Thanks for any suggestions! I am also head studding, and doing a lift pump, and adding a cts monitor instead of gauges. It's only money right?
