2005 model truck that is throwing a P1093 code. Truck has a new fuel filter in it, tank has been cleaned out, installed a new cp3 and still giving us this code. We have also tried a lift pump and will not solve the issue. You can clear the code and it will run fine untill you give it wot and then it throws the code and goes into limp mode and only will run 2100 rpms. I have followed all the all data on this code and have come up with nothing on it. Any input will help.
Thanks.
Thanks.
