Ok so as the title says my lly has a very long crank before fire.
Already replaced fuel filter housing and a new filter. Had the whole system tested.
This happens all the time. Hot, cold Temps and engin running hot or cold. Sometimes it's a 5 second crank. I watched some videos and seen where the factory guage will stay low a bit after its started cause of glow plugs. Mine does not do this. It shoots right up to pay 14 after it fires. I also just went out and put a volt meter on my driver side battery and it showed 11.8 volts with truck not been running for 12 has and 35 degrees outside. Truck cranked for 3-4 seconds and fired up. Which I would feel is normal in cold weather. So that told me the glow plugs seemed to work. Could my batteries be weak and that's why I have a long crank. It cranks fast, just struggling to fire. I hate this truck for this reason. And need it fixed. I have more info about issues I have had with the truck but wanted to get the battery question out 1st
