LLY/LBZ MAF differences
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
LBZ intake in LLY, this has worked great for the trucks I have done
Grams per second (not lbs/minute)
B0201
0.000000
0.000000
17.500000
23.679688
29.187500
34.648438
40.562500
47.312500
55.203125
64.453125
75.203125
87.539063
101.500000
117.093750
134.304688
153.101563
173.468750
195.398438
218.906250
244.046875
270.945313
299.757813
330.742188
364.226563
400.664063
440.585938
484.679688
500.000000
Cougar281
1,834
276
St Louis, MO
Mike, that's identical to the table I posted earlier, just in g/s instead of #/min. Just FYI.
B0201
0.000000
0.000000
17.500000
23.679688
29.187500
34.648438
40.562500
47.312500
55.203125
64.453125
75.203125
87.539063
101.500000
117.093750
134.304688
153.101563
173.468750
195.398438
218.906250
244.046875
270.945313
299.757813
330.742188
364.226563
400.664063
440.585938
484.679688
500.000000
Redbowties88
Sideways > Straight ;)
Aug 24, 2009
1,943
609 New Jersey
Thanks guys. Well it's not a stock lbz intake I'll be using here but a banks for an lbz. But it should be the same as the design it to well, work :D
05' Ditry Duramax
May 3, 2008
1,294
42
Port Orchard Washington
Well, the LBZ & LLY tables aren't identical, just similar, so no, you couldn't just copy them. If your LLY has the "flat" airbox, no change needed. If you have the 06+ airbox, but haven't changed the tables, you probably should. Even if you're not setting codes, it might not be running to potential...
I see what your saying now. I still have the K&N filter on there. I might try and rescale it and see what happens. Thanks for the info.
Diesel Pilot
Hat? Suitcase? 50 BMG?
Aug 9, 2006
1,424
47
Pickerington, OH
Here is what I have found and it won't help you at all.
The truck will tell you what it wants. I've had LLY's (mine and a few others) not need the conversion in the tuning at all. My truck has never thrown a MAF code with what ever tuning I put on it and it runs great with the hybrid LLY/LBZ intake(s) I have used on it (multiple setups).
Now, there are a few other LLY's that have been a real PITA to tune for with LBZ setups. I mean not throwing codes for a while, then all the sudden won't run right PITA.
I think it might have something to do with operating system or the difference between 04.5 and true 05's, some 05's don't have a problem. IDK. I'm happy my truck is easy and I don't have to fuss with it.
You'll just have to see and the advice that the other guys have given is top notch and I would definitely try those things first if your truck doesn't like the LBZ setup.
Redbowties88
Aug 24, 2009
1,943
609 New Jersey
Can't answer your question, but I can tell you banks will sell you an LBZ intake tube. I called to order one for a friend who was using the LLY tube and they said they would sell it to me.
Per their email....
The only difference between all of the current Ram Air kits for the Duramax is the Intake tube. The Intake Tube for the LBZ Ram Air intake is part number 42152 and retails for $59.59. You can order that part through our Customer Service department at 888-839-5600 or Tech Support at 888-839-2700.
well unfortunately that quote is a load of shit. i would expect nothing less from the people at banks. it doesn't fit onto the lly airbox lid the coupling is too small.....so now i guess ill call them tomorrow and see if either A. i can get the LBZ airboz lid and if it will fit or B. send it back for a refund, eat the shipping both ways, and still have a shotty connection there.
life is good:rolleyes:
Redbowties88
Aug 24, 2009
1,943
609 New Jersey
well i managed to man handle it all together. not a great fit but much better then before. MAF is ll wacked out even with the updated table...so im working on my own table now to hopefully make it work
Redbowties88
Aug 24, 2009
1,943
609 New Jersey
ok well im still getting a DTC....but only the 102 code not the 101 anymore...
MAF reads somewhat normal. i regret not logging more with the original setup. but just by going off what i remember off the top of my head it seems about correct. it trips the code at idle even though i programmed it to never read lower then 5 lbs/m. so far here what my table looks like. appears to be driving normal
4.999657
4.999657
4.999657
5.481228
6.756461
8.020327
9.389601
10.952123
12.778165
14.919399
17.407861
20.264217
23.495703
27.105418
31.089230
35.440937
40.155372
45.231502
50.673460
56.493649
62.719969
66.138500
66.138500
66.138500
66.138500
66.138500
66.138500
66.138500
66.138500
66.138500
66.138500
66.138500
66.138500
Redbowties88
Aug 24, 2009
1,943
609 New Jersey
EDIT: looked at the wrong table i see where your coming from...
but just setting that code to not report should accomplish the same thing slightly easier right?
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
No. setting parameters to a certain value changes there operation.
Setting a code to "not report" just covers an issue.
People, simply turning a code off is not a good idea. If you are getting a code there is a issue, and 99% of the time you can adjust the tune so you dont set a code. Setting a code to "not report" does not require EFI Live, you can stick a piece of black tape over your check engine light much cheaper. :D
Redbowties88
Aug 24, 2009
1,943
609 New Jersey
yea but its the same thing in less action. making the counter go to 65000 before the code triggers is just like turning it off. the errors are still there it just takes an insane amount of them to set the code. if there was a real problem you would still never know.
i tried fixing it with the flow table as that would be ideal but this intake is just too wacked out to correct. its almost like a bubble where the MAF sits. real fat and skinny before and after. so the air going over it must be going really slow
Redbowties88
Aug 24, 2009
1,943
609 New Jersey
well im not trying to be a dick or anything just saying.... is there some difference i dont understand?
i see what your saying for most situations and i agree. but for this one setting the error count to max and setting it to not report at all seem to be the same thing to me
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
Im not saying your coming off like one lol.
Forget the codes and the test enablers, fix the tables. Logging what the truck is actually doing will be a huge help.
Redbowties88
Aug 24, 2009
1,943
609 New Jersey
yea ive been logging...well not logging more like watching and not recording. maf is all over the place at idle +/- 5 lbs/m smooths out when your driving though..
