LLY: Lly issues
noahshipwash
Apr 5, 2017
15
So this morning noticed my truck was hard to start let the gloplugs heat like usual even though it was nearly 60 f this morning, I've started it 5-6 times and it turned over a lot more than usual every time then this evening it was hard to start them idled for about 30 seconds and cut off, then hard to start again but fired right back up and surged for a second and quit I have no clue what this could be any help greatly appreciated.
2004.5 lly 220k miles straight pipe intake egr delete lift pump and efi live
jlawles2
1,057
Danbury, TX
Check the fuel filter if it has not been replaced lately, could be plugged. if recently replaced, could be o-ring leaking.
KyleC4
470
Bay Area
Pump primer on filter head assembly and see if it ever gets hard to push anymore. If it doesn't would indicate leaking and drawing in air. Also sometimes just pumping it up will show a leak at the filter head. I've seen it slot around fuel heater
noahshipwash
Apr 5, 2017
15
I replaced the fuel filter about 1500 miles or so ago and the problem is just now coming up but I'm thinking about getting rid of stock filter assembly all together beings I have a lift pump and prior to me owning the truck the stock assembly was converted to the caterpillar filtration any opinions?
WVRigrat05
Wound for sound
Jan 1, 2011
3,081
French Creek, West Virginia
I've got a lift pump and run 0749 cat filters.
Shouldn't start hard with a lift pump unless an injector or injectors are bad.
I would check the lift pump pressure at the filter head to see if it's putting out and if so, I'd check rail pressure with the truck off and then see what cranking pressure is.
