Found a fuel leak a couple days ago and its losing a lot of fuel. From what I can see its coming out from under the holdown on the #1 injector?? (passenger side front). Park the truck and it'll leave a nice 12" diameter puddle within 5 minutes. Block is coated as is the underside of the truck and back window and tailgate. Drivers side is dry.
Checked the balance rates and all seem to fall within spec. If that's the #1 hole that's leaking, then those balance rates were ~+.50 ..... Holes 2,3 and 6 were all showing around +/- 2.0 in park, rest were less than that.
Tried tightening the hold down, nothing left to tighten. Got about 3* of turn in tightening the high pressure line on the injector, didn't wanna crank it too hard. Doesn't look to be coming out of there anyway, seems to be coming out from under the injector.
Not the return line, its dry as a bone.
Anyone had this problem before?? O ring got pushed, cracked body, what else could cause this?? Gonna pull it out tomorrow, just curious if anyone else had this happen and what caused it. Thanks
