Ok before I attempt to put in a high idle switch I want to make sure I have all I need. Run a wire from ECM c3 connector pin 6 L-GN PTO on switch signal? Or pin 39 PURPLE pto control? Ok so one of those to a switch, then power from green brake switch wire I believe then ground switch. 3 post switch. Does this sounds correct?
