LLY: lly help
Ri$h
Ri$h Racing
Mar 28, 2009
Kansas
new to the duramax, just bought a 05 CC 2wd, i have a msd dual sweep boost/egt gauge, and i orderd a egr blocker kit and boost stick from kennedy diesel. i was wondering what programmer or chip to use with these mods i am going to use??
kodiak
Sep 25, 2007
178
It makes no difference. Just so long as you can clear the codes....IF they should come up.
Big Block 88
Multiple choice muscle
Nov 3, 2008
4,665
Kansas when I am home
Just don't call them a "CHIP" and all will be well. What tuner you want depends on how much power you want and what you want your truck to do. Seein as you came to a raceing site I am kinda bettin you want to haul ass I would go with PPE or EFI the 2 best tuners IMO.
Oh and welcome!!!!!:hello::hello:
Ri$h
Ri$h Racing
Mar 28, 2009
Kansas
ok thanks for the info, i tried a superchips programmer today and it didnt seem to help at all, i couldnt tell the difference from stock.:( i gutted the catalyst already, read that the stock intake tube from the turbo is the problem?? thought about reaming it out myself?? any suggestions??
Big Block 88
Nov 3, 2008
4,665
The LLY mouth piece is a big problem, you can ream it yourself or get with killerbee and get one of his units. Superchips is not well never mind... lets just say I don't like them.:toilet_claw:
Ri$h
Ri$h Racing
Mar 28, 2009
Kansas
lly helo
thanks, how much is the mouthpiece?? i could do it myself cheaper dont you think?? Also wondering if a cold air kit is worth the money?? couldnt i cut my stock box up below the filter and be the same as cold air??
LBZrcks
Jun 2, 2007
5,297
12
SoCal
Welcome!
Since you're blocking your egr, I would use a ppe tuner or EFI Live. Not sure if any other tuners out there block codes for blocked egrs.
othrgrl
Diesel Addiction Owner
Mar 10, 2008
2,151
Wilmington NC
www.mydieseladdiction.com
First the only tuning I would recommend is EFI Live. You can never outgrow it and the possibilities with it are endless. You can delete any codes you need to, eliminate the need for any boost sticks, EGR fooler sticks or any of that other stuff.
The LLY turbo inlet is very restrictive and IMO the best solution is to get one from an LBZ and then either modify an LLY intake or use an LBZ intake system with it.
Ri$h
Ri$h Racing
Mar 28, 2009
Kansas
Welcome!
well i bought the finger stick with the egr blocker and its supposed to cure the SES light and codes, rite??
Ri$h
Ri$h Racing
Mar 28, 2009
Kansas
were would i get one off a LBZ?? and i would like to get efi live just cant afford it rite now, how much could i get efi live for any way??
Big Block 88
Nov 3, 2008
4,665
799 bucks and EFI is in your hand, there are some very good vendors here that can help you out with all of your needs.
Check local junk yards and ebay for LBZ mouth pieces.
Ri$h
Ri$h Racing
Mar 28, 2009
Kansas
The fingerstick will do just fine but a PPE or EFI would make more go fastyness
ok, well i dont want to make too much HP or tourque that it fries my stock allison trans. my truck already has 122XXX miles on it, how much will my stock trans take??
Ri$h
Ri$h Racing
Mar 28, 2009
Kansas
wow 799 thats a good chunk of dough:eek: im sure its worth it but i will have to wait, maybe they will get cheaper???
LBZrcks
Jun 2, 2007
5,297
12
SoCal
They actually went up $50. But you can look at it this way, It will eliminate using a boost stick, fingerstick, can tune 2 different trucks right out of the box, you can add a 2 or 5 position switch to change tunes on the fly for your LLY. And you can datalog and use it as a tool to diagnose a problem if any. I know I'm leaving some things out but it has a lot of abilities.
