LLY Got hot
Max Attitude
11SIX
Mar 7, 2012
814
Caledonia, MI
Couple weeks ago I was towing my 96 Z-71 ext cab on a trailer home from the dunes. It was hot out, 88* according to my truck. Cruise set at 75mph, I turned on the AC about half way home (1.5 hour trip). A little later the fan kicked on and my coolant temp got up to around 230*. I turned the air off and it went back down to normal 210*. About 5k miles ago I replaced the water pump with an AC Delco because of a seal leak. I don't tow often when hot but never had an issue before. I have a full LBZ intake/mouthpiece with down pipe and straight piped exhaust. I was running on my EFI tow tune. I may have to clean the cooling stack I guess? I know the LLY doesn't have the best rep for cooling but I'm not running through any mountains here.
RickDLance
1,276
14
I would definitely clean the stack. Be sure to disassemble it and clean from the back side to the front.
ALLY Fox
Old Man Truck
Dec 14, 2010
434
Oregon 7S5
The dash gauge is notoriously inaccurate if that's what you were going by. Mine says 210 when actual ECT is 186*. Plus, towing at 75 is a strain on the LLY cooling system when OAT is approaching 90*, especially if you're running big tires.
carl.swoyer
Jan 31, 2016
90
Might check out the clutch fan. Mine was slipping just enough to get hot more frequently . Put a new one in No more running hot. Plus have your tow mode on
Sent from my XT1254 using Tapatalk
610
Whats different about them? I don't even want to hear the fan come on at all.
The Hayden starts partially engage the fan around 190 and is fully on by 200° vs OEM on/off nature around 230.
Its sensitive enough that turning the AC on will partially engage the fan at idle with exception to trucks like james most of us that have done the swap rarely see any coolant temp above 210°
Max Attitude
11SIX
Mar 7, 2012
814
Caledonia, MI
Ricks suggestion should help. Made a video of it. If not familiar with the audio you probably won't find the humor in it. Sorry its vertical too. :eek:
[YOUTUBE]AXUUqnfEYOc[/YOUTUBE]
