LLY EGR Delete..
EGR Delete?
  • Total voters
    27
DuramaxTireSmoker
Jun 8, 2010
339
SW Florida
Here's the deal.. I may be looking at a good deal on an egr delete kit:D My question.. I have the EGR blocked and my truck basically never runs over a stock trans safe tune - Is it worth it to delete the egr? Give me reasons.. thanks;)
Colt
Jul 23, 2010
523
Can't recall one even wanting to keep the EGR for any reason. Once I was on to that delete from All Season it was the thing we wanted for as long as we saw it on the truck. Tony made it work with the heater grid for our cold ops. Thanksgiving right there!!!!
9,903
149
Unless you change your turbo, the egr starts leaking, or your hell bent on changing the intake pipe to the Y-bridge, I don't see the point in removing it. Just a bunch of un-neccesary work. Blocker plate does it's job just fine.
SgtKilroy
'Merica!
Sep 30, 2009
859
SoCal
I'd get rid of it ASAP just because it's ugly, takes up space and brings back bad memories of cleaning the sludge out of my Y bridge. :rofl: Depending on your state's inspection processes, I'd keep the parts though. :thumb:
DuramaxTireSmoker
Jun 8, 2010
339
SW Florida
I dont need to worry about inspections. What got me going onto this was the other day i blew the radiator hose that goes to the egr cooler.. Thanks for the input so far. How long would you say for a beginner to install?
3,727
296
Personally, I don't think it would be worth the effort, since it is already blocked. But, if you got a good deal on the kit, and have a free weekend, then why not?
SgtKilroy
'Merica!
Sep 30, 2009
859
SoCal
Not really difficult at all. Plan on losing some coolant when you unhook the cooler though. And whatever you replace the riser with, make sure it's supported or you will pop the inlet out of your y bridge. Royal pita to get back in. I have a black egr delete pipe for a lly that I made sitting in my garage right now. Already tapped for a boost fitting. Let me know if you're interested.
ripmf666
15,123
14
47
Wentzville Mo
some pictures might be nice. I'm looking to get a colored one..
If you already have a good deal on this from someone. This someone that your buying this from should have pics and colors? Is this person a vendor on this site or does any of the vendors on this sell this persons egr delete kit. I only know of 1 kit that is sold for the for the lly egr delete there was 2 but I dont sell the one Paul made for me anymore just the RDL kit.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
x2. If its blocked, its not hurting anything just sitting there.
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
I have a used RDL one we pulled off my Brothers truck when we put his twins on , if you interested in replacing it anyway , and can get it coated any color you want PM me if your interested.
btfarm
you know
Nov 25, 2010
387
Sandwich, Illinois
I'm not running EFI (I have a predator) so I believe I'll need a "finger stick" when the blocker plate goes in (on an LBZ). Correct?
I've put this off FAR too long...
I intend to do pcv reroute at the same time. Sometime over the winter.
DuramaxTireSmoker
Jun 8, 2010
339
SW Florida
Just to clear a few things up its from a vendor on a different forum. I'm getting at a good deal because it is not on the market yet and i will be sort of a "test guy" but thanks for the offers tho!!
SgtKilroy
'Merica!
Sep 30, 2009
859
SoCal
Sounds good. If you clamp the hoses going into the cooler before pulling it you will loose a lot less coolant. Then just splice in some new heater hose and that part is done. You will still need a non emissions up pipe or weld a cap on the old up pipe though. I just cut the small pipe off about an inch above the main pipe, heated it up, folded the metal over with a hammer and welded it shut. Easy and free!:thumb:
glamis_addict
Jul 25, 2011
New to this forum, referred by fast03... I need to post 1 reply before I can start a tread so hope this is a good start!! I am in the process of doing the lbz mouthpiece on the lly install and im at the part where it says to bend the line on the egr cooler aprox 3/8" and now my cooler has a drip at the weld. I now need to either replace my cooler, get the block off kit or weld my current one. Any help would be greatly appreciated !!!
1lowdiesel
<- wish i was there
Sep 18, 2008
1,615
In
I've got a cooler delete kit for sale if you need one.
The only way you could weld it would be tig, but imo it doesn't make sense to keep it on there if you're blocking the egr anyway.
