I bought this truck earlier this week. 05 lly twins, trans, lift pump, ect. i've noticed when I come to a stop my truck raises rpms by like 50-100 rpms then settles back like it was before it does this. Then if you let off the brake and roll faster then 1 mph and hit the brakes it will do it again and evverytime you do it. If I put my switch to the default tune it wont do it. It does on the other 4 settings. It's enough to bug me. I looked at the tables in idle and fuel pressure graphs and everything looks fine and nothing abnormal. I belive it has something to do with the dsp5. My os I'm runnning is 05160005. I did check to make sure the switch is working in my drive way with the scan tool by logging it and noticed that the voltage will go from where it needs to be on #2 setting then bounce to the default setting as the voltage goes out of range. It did this about every three or four seconds. Just wondering if my os isnt working properly or something or if the wires going into the ecm arent making good contact. Can't find where anyone else has had this issue. Any help would be appreciated. Oh and the DSP5 was installed prior to the twins so I have no idea if it did this before. Thanks!
