Little turbo
03 D-max
Honorary "Tosser"
Apr 29, 2008
3,539
Lowville NY
854 cc (24.6 hp) liquid cooled, 3-cylinder , 4-cycle Yanmar diesel engine
what do you think i could get for a turbo for this thing. It needs more powa!! adding fuel is no prob:D
Whitetail Addict
Rockin' the stock tune
May 8, 2008
2,350
South Central Pennsylvania
A turbo gator would be cool...especially out at Schieds. Might want to try a charger off a 4bt, it would be a Holset but not sure of the number.
Sorry, I don't know much about chargers...just my truck has one and it makes a whoosh sound :D
03 D-max
Honorary "Tosser"
Apr 29, 2008
3,539
Lowville NY
HAh thats about how much i know about turbos too lol
hoping to get this thing to go like one SOB :coolspot:
05' Ditry Duramax
May 3, 2008
1,294
42
Port Orchard Washington
Would a take-off from a Volvo gas-burner be too big?????
I was thinking the same thing. My Saab has a tiny little thing on it. I think my wifes hair dryer puts out more air than that little turbo does. Maybe you can call a few junk yards or do a search for those gas pot turbos off some of the saab, volvo, audi's ect.....
03 D-max
Honorary "Tosser"
Apr 29, 2008
3,539
Lowville NY
searchin right now. turns out there not as big as i thought
03 D-max
Honorary "Tosser"
Apr 29, 2008
3,539
Lowville NY
these saabs and volvos only run like gt17's and i think that would be just about perfect:D
The next rainy day i get i will head to our local junk yard and search the lot :Charger:
mytmousemalibu
Cut your ride, sissy!
Apr 12, 2008
2,230
Kansas
JD had a tiny S200 on some stuff, even had a Deere cast into the housing:D Prolly be perfect. Check Ebay.
Id also look for a diesel Smart car turbo on there.
Its gonna need a tiny hairdryer too spool up! a Gasser one might be hard to get goin.
03 D-max
Honorary "Tosser"
Apr 29, 2008
3,539
Lowville NY
Yah i have been looking at turbo maps and i dont know if i could get a gasser turbo to spool. :confused:
but i will defiantly keep an eye on ebay
racinmike77
Sep 14, 2008
1,029
MD
A gt 12 is plenty big you should be able to make plenty of power with it. When looking at compressor maps multiply lb/min by 10 and it will be close to the hp output. As for pressure ratio 1= 15psi boost 2-30psi 3=45psi at STP. So at a PR of 2 roughly 30psi a G12 in its map will be pushing a motor to 50-100hp, I honestly dont think you will have enough fueling and dislacement to push a GT12 to 30psi. For you application you will definately want something small that spools quick and you should invest in a wastegate.
