Limped the Trans on the LLY
Bdsankey
4,230
1,334
Larsen, Wisconsin
Did you not read my post? I said valve body, harness, trans cooler fittings. Been there done that 9 years ago.
Iirc the bell housing thread sizes are different for those cooler fittings as well. I deleted my factory lines and went full braided cat hose and jic fittings.
I did, but the statement that they are all different is incorrect. There are various differences based on the year/model. That is the point of my post. Depending on the configuration of the trans the OP uses, there will be varying things that would have to change.
Correct, the thread size is different and the actual line itself is different in terms of the collar/inserted length. If the OP is not going to use aftermarket lines, he needs to buy the appropriate adapter fitting set from GM (they're $20-40).
A_T_Ver
416
Go with Evan and you'll have a great kit and the customer service that goes with it.
Burn Down
Sep 14, 2008
7,092
Boise Idaho
Wouldn't that mean they all are different between models and years? My statement was correct, he can use any trans from 01-10' with various part swaps and mods. Instead of writing out a graphic novel, I kept it short and sweet.
