limp mode on new trans
Mpsoldier
That just happened!
Mar 10, 2010
646
In my House
Hi guys i just installed my new built trans but cant seem to get it to clear the limp mode also my linkage is off by one gear any help will be useful thanks. Do i have to re flash the computer?:confused: any help will be appreciated
Mike L.
15,681
232
Fullerton CA
Need info.
Mpsoldier
That just happened!
Mar 10, 2010
646
In my House
trans is rebuild with the suncoast kit and ml presion tq truck is a 2002 lb7 with a s475 over stock efi live simple 140hp tune. 4x4. i can clear the light but as soon as i do it comes back idk if i messed up the wiring some how pretty simple but never no. couldn't see anymore tonight. the trans before was the stocker that i beat pretty bad. the linkiage wires are hard to get in i was thinking it might be one of those wires if anything could be wrong.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
What code(s) would be a big help.
Sent from my PC36100 using Tapatalk
Mike L.
15,681
232
Fullerton CA
codes are as follows tcm p0708 pcm p0380, p0700 sry had to run out in rain.
NSBU switch is where I would start. P0380 is not a concern. If your linkage is a notch off, it is bolted on backwards. The ball on the arm needs to be pointed outward.
Mpsoldier
That just happened!
Mar 10, 2010
646
In my House
Thanks for your guys help it was a connection on the nsbu switch, linkage is still little off going to play with it some its on correct thougt. and wow what a power difference with a built trans love it.:D
