limits on lb7 rods?
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
Torque kills stuff. Its not necessarily just "having the fuel" to bend rods, its how/when that fuel is injected and combusted (or not). I also think it is a balancing act making rods and pistons survive. I have seen broken or poorly calibrated injectors open too soon and ignite dodge cr pistons (400 some cc/min flow) which is way more fuel than you will be injecting. Straight rods and melted slugs With lots of fuel I would be more worried about pistons really shitting the bed. I think you are over fueling that 4088 and could at least upgrade it to a 4094 to cool it down as that 4088 is a relatively hot blooded thing, so take into account that the more fuel you put through an injector it gets exponentially hotter.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
I normally defuel tuning under 2500, and sometimes all the way up to 3000. IIRC, when we ran the GT45, it was ~800rwhp at 1200ftlb, but peak power was 4400rpm? Dunno, I'd have to look it up.
When racing, you don't need big power under 2500. And 1200ftlb is still lots of bottom end for launching.
The original fantasy I had 6 years ago was running a stock long block at 750rwhp by keeping the torque low, and HP peak up high. Many of our Casper engines were fairly low torque. Even at 750rwhp, it took a good number of passes before we started bending the rods. Obviously I didn't detorque it enough.
Big chargers are your friend if you're going to try and run big power on a stock longblock.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
As a rule of thumb:
2.6" charger 3600 rpm peak HP
2.8, 3800 peak HP
3.0, 4000 peak
3.2, 4400 peak.
The higher that peak is, the better your HP/TQ ratio is.
If you could peak at 5252, you could have HP=TQ, or 1200HP at 1200ftlb.
dieselson
1,544
30
Huntington Beach, CA
On our last motor, we ran a gt4088r turbo, duel fuelers, on the highest tune for about 1 1/2 years, with 80+ 1/4 mile runs and a dyno run to 618. When we tore it down to do the head gaskets, and decided to use a new motor, we tore apart the old motor and found that the rods weren't bent in the slightest, and the pistons looked good too. I definetly believe that tuning plays the biggest role in helping your engine live, because my dad was, by no means, easy on that truck. Hopefully this new motor should be good, dyno'd 654 whp so far with no problems at all as of yet and only thing done to it is head studs and C grade gaskets.
1,072
Morehead City, North Carolina
On our last motor, we ran a gt4088r turbo, duel fuelers, on the highest tune for about 1 1/2 years, with 80+ 1/4 mile runs and a dyno run to 618, and when we tore it down to do the head gaskets, and decided to use a new motor, we tore apart the old motor, and found that the rods weren't bent in the slightest, and the pistons looked good too. I definetly believe that tuning plays the biggest role in helping your engine live, because my dad was, by no means, easy on that truck. Hopefully this new motor should be good, dyno'd 654 whp so far with no problems at all as of yet and only thing done to it is head studs and C grade gaskets.
Thank you for that info! I appreciate the feedback from everyone. Good read x2
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
So who all is running 4k on the street? And is the general consenus that torque down low breaks or bends rods. And High cylinder pressure from long injection duration what kills the pistons whether cracking or just melting?
whitetrash21
put on da damn helmet day
Apr 29, 2008
4,929
Vegas
I run 4k rpm on my race tune, use it sometimes on the street. This is an LLY, same crap you LB7 guys are dealing with though.
5,911
ive been debating having trent run my tune up to 3600rpm but i dunno if the power will drop off that high. hhhmmmmmm
