Man that reads like a LOT of work but sure is soooo nice to see all that space to work!!!
hmm interesting...I do it a little different than Vinny, the wiring that is.
I basically just disconnect all of the plugs from the underside of the fusebox and let them droop down in the driver side wheel well.
That way you dont have to disconnect the start solenoid wire, chassis wiring, transmission wiring, and you dont have lots of wiring drooping down when the cab is in the air; it all just stays on the chassis.
Ive never found a need to remove the bumper, but as Vinny says, it makes it easier because especially on the 01-02 trucks, the bumper likes to get hung up on the core support. 03+ trucks its easier.
Ok, let me correct myself, it takes less time to pull MY motor, a stock duramax, would take probably twice as long as mine.
Just removed my first chevy cab today and joined this forum to thank you for the writeup. I just printed out your post and went down the list and it worked great.Takes me much less time to pull a cab than a motor. Dealing with the tranny is the most time consuming part in engine removal IMO.
That is a neat video, I can beat any book time on duramax work with the cab on, but I might try this once just so the ford guys in the shop feel threatened hahaha
Most of their book times are outrageous. HGs on an LB7 IIRC is 30.5hrs, takes a little over half that working comfortably by yourself. Water pump @7.5hrs. I'd love to do them all day, they hardly take an hour. 10.5hrs for R&R on transmission. Wish more of them failed. 12.4hrs for an up-pipe, why can't everybody blow them out.
Its not so much to success of beating book time, its the goal of beating it by at least 50%.
Just did another set a couple weeks ago. I'm still convinced the cab goes on faster than it comes off.
12.4 hours for an uppipe? where did this labor time come from? its 1.8 for right and 1.5 for left which are times i can easly beat on LLY's and up without any bolts breaking, LB7s do take mroe time due to the lovly down pipe set up. but still 12 hours? and a water pump in one hour? honestly i would love to see that i know with the fly wheel holding tool from the after market makes it so i can do them in 2-3 hours depending on model and rust
Bumping this back w/ a question. On the 6.4s i've lifted, half the cab cage nuts usually spin even by hand with heat. Is this an issue on our trucks?
