The install kit should contain two double barbed connectors so you can cut the excess hose out and couple it back together. AD is not difficult to install, just make sure you have good tools to disconnect the fuel fittings, cheap ones are not worth it here. I took my time installing mine and spent about two 2 hour sessions, I spent some extra time routing and labeling the wiring to make it clean and easy to troubleshoot if needed.
